MEXICOWANDERER
Nov 19, 2014Explorer
I love the idea of a single slice toaster and heater immersion coil when I am in a hotel room. Wake up, fix toast, french press coffee and I am spared a grumpy search for a restaurant that has drinkable coffee. Stop "Ewww'ing" already. You haven't lived until you've had toast with fresh mango jam. Of course if the power is off, it's either C Rations or nothing but I have used a Bernz-O-Matic torch to heat water for the French Press. Sheer desperation.
The quest is to find a tiny one slice toaster - methinks Snowman's is a double hole? None of this stuff will work with a Samlex 300 inverter, so that's out. How about a 12 volt toaster? One of those cheese grater battery "testers" has elements that glow, after all. Wishful thinking...
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
