jodeb720
Sep 18, 2022Explorer
I'm of the mindset that the gearing on your new unit is lower than in the past - probably to save money. If the drive motor is smaller, and weaker, how do you still lift the weight? Gear ratio is lower.
so when you turn release the Up and immediately are going down, the motor may still be spinning and that will cause the fuse to blow (like others have said, wait for it to completely stop).
Personally, that would annoy the heck out of me, but as long as I understood the "why" i'd just accept it and go one.
Like others have said, you need a backup - and the manual crank is that backup.
And don't let others fool you - my manual crank died many a year ago on my TT when I had just pulled into Yosemite and was ready to disconnect. The connecting pin either fell out or vibrated loose and I couldn't crank up to disconnect.
Eventually, I made it work enough to disconnect - and jacked the trailer up and lowered down under the tongue using wood. Once I did that I spent a wonderful afternoon completely stripping down the manual jack, re-greasing it and reassembling it and it probably is still working to this day...
The point is everything can and will break - but you need a backup.
josh
josh
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
