Old-Biscuit
Oct 29, 2013Explorer III
trtog7 wrote:
It is 2013 Allegro 35QBA
50A rig?
IF yes........you can use an adapter that allows you to plug into a 30A power receptacle.
You will be limited to 30A total load so that means you can not run everything that you would be able to run when using a 50A power receptacle.
Yes you can run the WH while on 30A......just may not be able to run A/C or microwave at same time.
Just takes a little load management when you are a 50A rig and plugged into 30A service.
We are 50A......we use 30A many times. We can run WH, fridge, TV, the 12V DC items, have converter charging batteries and are OK.
But if we want A/C or microwave we just run WH on propane (or turn it off until needed).
Not a big deal :B
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
