BFL13
Jul 23, 2020Explorer II
Good that the converter works after you replaced the RP fuses. You had that right it would protect itself.
Some controllers want you to always disconnect the array first and connect last or they might fry. Yours obviously does not care about that. So connect it to the batts.
What smoked? Did you answer the earlier question about the jacks? Didn't see that. Usually RP just means the lights work but the fans run backwards.
The gen starts from house batts. The trouble started before you swapped batts and got the RP? Look at the gen DC cables for any melting. (Guessing here!)
