BigWapiti
Jul 23, 2020Explorer
Joe417 wrote:
My 2 cents worth of experience.
I had smoke from under my sink while on generator about 2 years ago.
Was the AC wiring inside the automatic transfer switch. I posted picture on the forum but didn't find them when I searched.
Over time the wire nuts had loosened and gotten hot or someone may have left them loose.
The heat it generated melted and blackened the wires back about 3 inches from the wire nuts and finally burned one wire open. The switch still worked but the contacts had been too hot so I ended up replacing the switch. I was able to pull enough wire back to cut off the damaged area. Cost was I think $30 or $40.
I'll definitely go in and check those too, thanks!
But you say 'automatic transfer switch' - is that what I'm seeing labeled the Power Controller?? I'm learning all this new RV lingo.. pardon that.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
