trop-a-cal
Oct 06, 2014Explorer
Electrical 12Volt
After replacing the engine battery due to the old one dying for an unknown reason, the new one did the same thing. I have a battery boost switch that is spring loaded so it goes off when you stop pressing it. It uses house batteries for the boost if engine battery is not turning engine over. I believe the pressure switch may be not going off due to age,(18years). Has anyone had that problem with a bad boost switch? If that is not the problem then juice is being drawn elsewhere, which I can't locate so far. The unit is a 1997 Tropical Chevy P32. Thanks for your help. Only other odd thing 12 volt related is the starter switch for the generator, when engine is running causes the speedometer to jump when holding that pressure switch down. It's like a back feeding, maybe diodes are needed to isolate current, or dash has the short causing both?
