Boddhisattvha's avatar
Oct 19, 2013
Electrical Assistance with a furnace please
Hi all,
I just installed a new Suburban NT20 furnace and I need some help with the wiring. There's only four wires, red (hot) yellow(grnd) and two blue which are for the t-stat. My issue is that the damn installation manual makes no real differentiation between the two blue wires. There's a red and a white wire coming off the tstat and I assume red is hot and white is something else and they would need to attach to the corresponding blue wire(s). I don't imagine they are interchangeable? The wiring diagram only shows where the wires go in the actual furnace, but unless I take the furnace apart and track the wires I have no way of knowing which is which.
Anyway I got it installed and tried to turn it on and nothing happened. I switched the blue wires and still nothing happened.
I'm going to call Suburban on Monday but I figured I'd see if I can get it resolved with your help first.
  • Okay, I tried it and no go. I have a suspicion that I didn't get it grounded well enough. If that's not the case than either A. the furnace I just bought is bad or B. the hot lead coming in has issues. Are there any other possibilities I should look at?
    I actually just installed a new thermostat a few days before the old furnace died. (The old furnace just stopped lighting the blower motor was fine) The new thermostat is Heat only White Rodgers
  • What thermostat do you have? On a Coleman thermostat that operates the rooftop air conditioner, it does matter, as the thermostat gets its power from the furnace.
    Agree to try hooking the blue wires together first as a test though.
  • Yes, connecting the two blue wires should start the furnasce fan and then in about 10-15 seconds the heat should start.
    The thermostat is normaly just a contact closure.
  • You mean just bypass the thermostat and wire the blue wires to each other correct? And that should make the blower motor come on?
  • Hook the two blue wires together. If furnace dose not come on then you have other problems.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
