wbwood's avatar
wbwood
Electrical Assistance
We have a 2013 Class C motorhome that came with a 32" Jensen LED 12 volt tv. It is mounted in a frame with storage behind it. In the last year, we blew the inline fuse in it. I noticed that the wiring got damaged from opening and closing the storage area. Basically it pinched the wire. I spliced the wires back and put in a new fuse. TV worked. After watching it for a while (few hours) on the next camping trip, the inline fuse blew again. I noticed it was hot to the touch. The tv is 7.5amps. The inline fuse holder has a sticker on it that says 8amps. I replaced it with a 7.5amp fuse and it blew again, and once again hot. So I ordered some 8amp fuses. Replaced the fuse with an 8amp one and immediately starts getting hot again. I removed the fuse and did not attempt to use it again.
Any idea of why this is happening? What can I do to correct it, short of purchasing the AC power supply for it or replacing it with an AC tv?
