jseyfert3
Nov 06, 2019Explorer
Hurricaner wrote:
How exactly did you check for dc voltage at the fuses? My guess is the only fuse that has power is blown due to the negative meter lead being on a positive.
Sam
Seconded. My first thought when I read that all but one had voltage was that it was a measurement error and the one with voltage was blown.
OP: No offense to your skills (which are unknown to me) but you didn't happen to measure voltage from that top red wire to the wires coming off the fuses, did you?
EDIT: I re-read, saw that lighting is out (which is on the fuse with voltage). I'll bet a case of beer you measured voltage from the top red wire to the wires coming off the fuses.
Doing this will only show BAD circuits, typically blown fuses. A better way of doing this is to measure from negative (no terminals shown in your picture, metal casing may work) to the wires coming out of the fuses.
Measuring from the top red wire (12 volts) to the output of the fuse (12 volts) will show 0 volts for a good fuse and 12 volts for a bad fuse.
Pull fuse #1 again, measure the resistance across it using your voltmeter. If bad, it will read high resistance or NC (no connection), depending on the model of meter you're using. A good fuse will read almost 0 ohms.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
