Dutch_12078
Nov 01, 2021Explorer III
dougrainer wrote:
PS, I have 42 years as a RV tech and one thing I have learned over those years is that even LICENSED ELECTRICIANS, have problems understanding 30 and 50 amp RV plugs.
If the electrician doesn't understand how to wire a NEMA 14-50R for a 50 amp RV, find another electrician. The wiring is identical to the NEMA 14-50R for a residential range.
30 amp is a different story. For some reason some electricians can't read the "120-volts" label on a NEMA TT-30R outlet and confuse it with wiring the "120/240-volts" NEMA 14-30 outlet, or the "240-volts" NEMA 10-30 outlet used by older dryers.
