WASTATELIVING's avatar
Nov 01, 2021
Electrical issue on 50amp service
I've got a new fifth wheel on 50 amp service. Recently we have lost power to all of our outlets and both electric fire places. After checking each plug, checking to ensure no breakers are popped, all fuses are intact, and the source is good this is what I've discovered.
The power supply cord is supplying 120v on both legs. When plugged into the RV our LED light above plugs shows power. At the breaker panel however, the red leg shows 120v and the black leg shows 70v. which matches the voltage I'm getting at the outlets. This is BEFORE it even reaches the breaker. I am assuming that the issue is in the inlet plug on the wall of the RV. Either a loose wire or it just needs to be replaced. I'll be opening it up tomorrow to take a look and replace it.
Any other ideas, something I might be missing?
Thanks
-Dre
  • Had a neutral come loose and lay on a hot leg giving me 220V at the micro, smoked it!!!
  • Great discussion and information.
    We are at an RV park and our auto transfer was jumping in and out last night. Never had a problem with it before so I disconnected for the night and used batteries and propane.
    This morning I dug out a volt monitor (very handy, just plug in and look at it occasionally), and I noticed the power generally a little high, average 126v. We also picked up an inline 50a surge protector.
    Power was OK all day until about 6pm, then the transfer started jumping in and out again and I saw volts go up to about 160. Yikes! On my dash to shut off the main I noticed the surge protector indicator lights were steady blue/green (normal) with occasional red (Open neutral).
    A few simple tools revealed the problem. It's easy to get lazy about monitoring your connections, especially if you have never had a problem. But it is no fun doing repairs while on vacation.
    BTW, we blew out a water line 2 years ago due to water pressure surge and not using a regulator. What a pain to repair that, not to mention no water for the remainder of the trip. And...I still forget to use the regular.
  • Voltage to 160 STRONGLY suggests a bad neutral.
    Suspect if you check voltage on the other line (L1 vs L2) to neutral or ground it would be LOW.
    No idea if this is in your coach or shore power cord or in the CG wiring.
    Care to share the specific diagnosis and repair? You have implied a bad neutral, but that leaves a lot of possibilities.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
