Rygar's avatar
Rygar
Electrical issue
Checked on the fifth wheel in storage today. Batteries were dead. They are 5 years old so I knew I was on borrowed time with them anyway. Towed to my local battery store. Have two 6 volt batteries that tested at about 2 volts max. Had them replaced. Mechanic tells me after he installs them that something must be turned on because he got quite a spark putting in the new batteries. I checked all through the rv and everything was turned off. Anyone have any idea what could cause this? Could there be an electrical draw somewhere and how on earth could I find it?
  • most likely just the filter caps in the converter
    UNless the emg break-a-way for the tt brakes is on check the pull pin for the break-a-way switch
  • Did he have it plugged into AC when he changed the batteries? Converter or inverter/charger would certainly do that.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
