aliceinanthemaz's avatar
May 04, 2013
Electrical Issue
Need your advice for a novice RVer. I have a class C and now know that I was hooked up to 240V. I believe a power surge came through and knocked out my microwave, outlets, and ac. Everything that can run off the house battery is still running ok. But now even after correcting the hook up, the other items have not come back.
My dad is a dyi guy and we checked the fuses, one was burnt, we replaced it. We also tried to check the breakers. We had a test light and it appeared that electricity was coming into the breaker and then to rule out the breaker, we completed the circuit and the outlet to the microwave was still not working (we had a light bulb plugged in to see whether it would come on).
Any idea on what else is wrong? We plan to take it in on Monday, but was feeling anxious and would appreciate your opinions.
  • Mandalay Parr wrote:
    If you really had 240volts instead of 120volts, the microwave is probably fried along with other stuff.
    Yes, we are pretty sure the microwave is a goner, but was wondering what else we may have screwed up in the electrical system itself since even the outlet the microwave used is no longer working.
  • If you really had 240volts instead of 120volts, the microwave is probably fried along with other stuff.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
