surgtech56's avatar
surgtech56
Electrical issue
We have a 2011 Ameri-Lite. I plugged it into the house using an adapter last week. Everything was ok. Went out today, the microwave has power at least the clock is, no lights come on, I have refrigerator on auto, when I turn on lights the refrigerator light dims, refrigerator is not cold. Any idea thank you
  • that depends on the converter ?
    did you store the trailer all winter in your driveway with it plugged in and the NO battery ?
    NOT a good idea
  • I had the battery on a trickle charger all winter. The battery won't charge, I tried putting it on a charger.
    So if I don't have a fully charged battery hooked up, the electric won't work even if it's plugged into house current?
  • DrewE's avatar
    DrewE
    Explorer III
    Often the converter is mounted to the power distribution panel chassis, in a separate compartment. If it's not there, it would probably be a deck mount converter and that could be placed most anywhere.
    Without the converter or something else charging the battery, it's not surprising it's dead. It may not recover fully (or at all) with charging; lead-acid batteries don't take kindly to being fully discharged.
  • Where is the converter? Can I disconnect the battery? The battery is dead
  • Very common , usually involved one or more of these things
    Battery disconnect is used, battery not connected
    Bad cable
    Converter is bad
    40 amp automotive auto reset thermal breaker for battery is bad, located under frame near tongue, in main positive cable line
  • Battery voltage has dropped to almost nothing. Could be converter is shut off, so start there. Check output voltage of converter on 12 volt terminal strips. If it shows over 13 volts, then check at battery posts. If it doesn't show the same there, look at the connecting wires.
    In my case the negative feed to the battery at the converter terminal strip was loose, preventing the battery from charging.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Jan 18, 2025
