cavie wrote:
RLS7201 wrote:
So much bad karma about stab lock receptacles used in MHs.
When installed properly they will maintain a tight connection longer than screw down receptacles. Check any screw down after 6-8 years and they will be loose because of the copper crushing.
The stab locks in my 95 Bounder are all original and do not heat when using the microwave, coffer maker, PD9180 converter, or the 1500 watt heater.
Richard
Very interesting. Why do you think The NEC chooses screw down over Stab locks. Enquiring minds want to know.
YOU are the Master Electrician. YOU tell us. Doug
