TubaPete
Jul 07, 2013Explorer
donn0128 wrote:
Fuse . Refers require 12 volts to the control board. There is a fuse on the board and a fuse on the main panel. Either could be bad. Start by checking for 12 volts at the board and work from there.
I would look at fuses also. Refrigerator and AC only need 12V in the control circuits but all (OK, most) 12V circuits are protected by fuses, not the circuit breakers. Since your trailer is relatively new, it may have the 12V board where a little light lights up to show blown fuses.
