opnspaces
May 28, 2020Navigator III
I've heard of people plugging their three prong 120v trailer into the electric clothes dryer outlet in their garage and causing damage as you've describes. True the 30A RV and 30A clothes dryer outlets are kind of similar. You would think it's not possible to plug the trailer into a dryer outlet. But it gets reported here often enough that apparently it is in fact possible to do so.
But if you were in fact at a campground as you say then there should not be a 220v outlet to plug into. Did you use an adapter to plug your 3 prong plug into a 4 prong outlet? If so the adapter should have prevented the damage.
If you plugged your three prong cord into the sites 3 prong outlet and damaged your trailer. Then you need to talk to the campground manager or owner about replacing all the failed parts as the outlet is miswired.
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 22, 2026
