John_Wayne
Aug 26, 2017Explorer II
What is the shape of your batteries, if you have just the factory on off charger converter you may have boiled the water out of your batteries. You need to look into getting a Progressive Ind. 3 stage charger. Have you been putting water into the batteries??? Refrig. Heater, etc all need 12volt power to run the circuit boards.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
