07caddy
Jul 27, 2017Explorer
wa8yxm wrote:
First you screwed up when you replaced just one six volt battery. The reason is there are no six volt batteries in an RV.. Absolutely none.. What you have is a 12 volt battery that was split into two halves so as to make them easier to handle (And for a few other reasons that do not apply here .. Like cost)
YOu can't replace just half a 12 volt battery.. but you did.
Now. did you put it in the same way the old one came out (In series) That is the other mistake folks. INCLUDING SOME RV DEALERS, make with six volt batteries.
I understand now. thank you. I just replaced the old 6V with a new one so now i have 2 new 6V batteries. I put it back the way i found it, but that doesn't mean the consignment lot where we had the camper for the past two months didn't screw it up and i just repeated their mistake.
Nothing works without shore power or the camper running. So maybe I screwed up the in series wiring.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
