07caddy's avatar
07caddy
Electrical issues with Class C ... help!
We're experiencing sudden electrical issues with our 2011 Fleetwood Jamboree Sport 25G (E450 chassis). The camper sat for 2 months and prior to parking everything but the stairs worked fine.
Here's a synopsis of the challenges:
1. Interior camper lights only work if the vehicle is running or plugged into shore power.
2. The auxiliary battery switch only works when plugged into shore power or when the vehicle is running. Lights are very dim on the panel where I check status of batteries, tanks, etc).
3. Can only start the generator (from the panel)if the vehicle is running or plugged into shore power. I used to be able to start the generator with the vehicle off and not plugged into short power.
4. Electric stairs stopped working.
What we've done:
1. Replaced truck battery
2. Replaced one of the 2 6v house batteries (one tested good and the other tested bad).
3. Checked the fuses in the battery compartment under the stairs.
4. Checked the fuses in the converter.
We have the Intellitec Bi-Directional GAS Relay Delay, which I believe actuates a solenoid. When I turn on the aux battery switch I heard an audible click or thud.
I've read it may be a bad solenoid, the Relay/Delay switch, or converter. I have limited tools but willing to test/replace components. The soonest I can get it in for service is end of August.
Any suggestions on what to check at this point is appreciated!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
