mbowie1034's avatar
mbowie1034
Electrical issues
I have a 2013 Cedar Creek 36BHS. Currently camped in Georgetown, KY. Started having issues with the refrigerator blowing no cold air but still running. Then, we had to change sites; started setting up, lowered jacks, extended slides then different functions started shutting down. Now, the frig is still hot, jacks, awning, and slides don't work. Had a tech come out, diagnosed as a converter issue but took converter to CW and tested fine. Something is shutting down the converter right after it's plugged in- any ideas? I've checked all known fuses and no breakers are tripping...thanks!!
  • I found the problem! The power distribution block I referred to had small, plastic buttons on the hot side that apparently control the other side. Pushed them in and everything come to life- except the refrigerator; think that will be another issue..
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
