asherl33's avatar
asherl33
electrical issues
My grandson hooked my tt to his shop via power cord. tt is 30 amp. Everything worked ok for a couple of days. Now refridge, elect water heater and AC dont work. Light fixtures dont work. Microwave, area heater and table lamps do work. Before I talk to him, need input from veteran rvers. I don't use my TT. It is stationary. Thanks
  • wa8yxm wrote:
    That 30 amp outlet in the shop is almost certainty 240 volts.. Damage may be major.
    Yeah, like it would work for 2 days w/o smoke !!!!!!!!!
    Pay attention !
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • I know I'm a dunce when it comes to electrical issues. My grandson did mention hooking up my TT to 240 volt. Wasn't sure what he was talking about. He removed 30 amp to 15 amp adapter. If indeed the TT is hooked up to 240 V do I need a converter. Dont understand why my Micro, table lamps and computer charger work but nothing else. He's not around and I cant get in to his shop.
  • Check the units breakers first, do not forget the ones from the house too that could be the problem and is an easy fix
    (just re-set)
  • Check the converter output first, right on the output terminals. Either you have it there, or you don't. If you do, then you have to find the loose wire going to the battery. Could be the positive at either end, or the negative, or any connection, breaker, or switch in between.
    It's really very easy to troubleshoot, takes only a few minutes with a meter, so come back to this forum and tell us what your meter says.
  • time2roll wrote:
    Any chance that was a 240 volt outlet such as very common NEMA 10-30R?
    Doubt it........
    OP stated My grandson hooked my tt to his shop via power cord. tt is 30 amp. Everything worked ok for a couple of days,,,,,,,Microwave, area heater and table lamps do work
    The magic smoke would have escaped almost immediately
  • Any chance that was a 240 volt outlet such as very common NEMA 10-30R?
  • Like Chris stated..converter issue......loss of 12V DC power
    Converter supplies DC when AC power is available and maintains battery.
    If converter is NOT working then battery supplies all of the DC until battery goes dead.
    Could be converter has failed.
    Could be AC to converter has been tripped.....either a AC circuit breaker for converter has tripped OR if converter plugs into an outlet that outlet may be feed from a GFCI Outlet (Kitchen/bathroom) that has tripped
    As suggested......get a battery charger and hook it up to your TT battery to recharge it
    Converter DC output S/B 13.2V DC MINIMUM
  • Your 120 volt ac to 12 volt dc converter is not working- all of those things work off 12 volt dc power. If the converter is bad, a battery charger will get you through for a bit.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
