Hi all my first post here because of issues. My brother has a Wilderness 5th wheel and it started having issues with power. Sometimes it will run fine but with out warning it will lose power. It will ...
Your post is unclear to me. Rig operates on external genset and blows "fuse" when plugged in to where? Does it operate on internal genset? Fuses are normally on the 12 volt side and circuit breakers are used for 120 volts AC system. Does i have an automatic transfer switch? How often does it trip and what is being used. You could try turning off all circuit breakers in the rig and see if it trips.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
