Hi all my first post here because of issues. My brother has a Wilderness 5th wheel and it started having issues with power. Sometimes it will run fine but with out warning it will lose power. It will ...
You must disconnect the neutral from the water heater and turn off breaker. Did you unplug the refer? Common for the element to go to ground tripping GFCIs
