Tplat
Mar 18, 2021Explorer
Electrical Issues
Hi all my first post here because of issues. My brother has a Wilderness 5th wheel and it started having issues with power. Sometimes it will run fine but with out warning it will lose power. It will ...
Old-Biscuit wrote:Old-Biscuit wrote:
IF it is only having Electrical issues when on a 20A outlet....suspect that 20A is GFCI protected and one of the heater elements
Turn Off ALL Individual Circuit Breakers in the RV AC Power Panel
Then plug in/reset that 20A Circuit Breaker
If it Trips....turn off Both 50A CBs in RV AC Panel and try again
If it trips...problem is Adapter(s), RV power Cord,
If it Doesn't trip with RV 50A CBs closed...close each Individual CBs One at a time until the 20A CB trips....then ID that circuit and check it for loose wiring/bad connections etc
1st post PG 1
Follow it and find the circuit that is causing those GFCIs to trip
Only takes 5ma of current leakage from Hot to Ground to trip GFCI
