Tplat
Mar 18, 2021Explorer
Electrical Issues
Hi all my first post here because of issues. My brother has a Wilderness 5th wheel and it started having issues with power. Sometimes it will run fine but with out warning it will lose power. It will ...
time2roll wrote:Tplat wrote:You should be able to remove hot, neutral, ground in the electric panel and put a wire nut on each until you sort this out.
OK found a water leak along the wires for what I`m assuming is the hot water tank, we never used it and also never turned the breaker on for it. Will try the the breakers for the trailer tomorrow , not supposed to rain. Would cutting and capping off the wires or pulling the breaker work? We have access to a bathroom and such so hot water isn`t an issue.
