Perry_Ga_Camper's avatar
May 17, 2013
Electrical Issues
I have a 2009 Holiday Rambler Travel Trailer. The issue I am having is periodically the lights and fridge will go out. All other electronics will continue to work, including the a/c. Sometimes you can do anything you need/want to electronically, other times when you turn on a light all the lights go out and the fridge quits working. So far the only thing that I have found that fixes the problem (temporarily) is to shut off power, ensure all wires in the fuse box are tight, and then turn power back on. Has this happened to anyone else???
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
