Bobbo
Jul 27, 2019Explorer III
Build a bonding plug. About $3 if you do it yourself from stuff bought at a big box hardware store.
1. Replacement 3 prong plug
2. 3 inches of wire
Open the plug and use the wire to connect the GROUND pin to the NEUTRAL pin. DO NOT CONNECT ANYTHING TO THE HOT PIN!
Close up the plug and plug it into an outlet ON THE GENERATOR.
2. 3 inches of wire
