dryfly
Jul 27, 2019Explorer
OK, but first help me understand why there is an issue with the use of an inverter generator and the EMS system. Is the EU2000 a modified sine wave inverter?
After that maybe I can understand why bonding ground and neutral is a solution. I just found the Progressive Industries remote bypass switch, and this may be the easiest solution.
Again, I really need to understand what the problem is before I attract a solution.
The PI external EMS systems that plug into the pedestal sure seem to be an attractive solution but if I had one it would get stolen the first week!
