Planning
Jul 27, 2019Explorer
dryfly wrote:
I understand, regardless of the issue, why bypassing the EMS would work, but that seems like a lot of work.
We have a hard-wired Progressive Industries EMS-HW50C. Integral with the system is a control/display panel with a switch that allows you to bypass the EMS for generators with unbonded neutrals.
PI actually used to sell a pre-made plug to plug into generators similar to the illustration above. (I have one, and use it on a small faux Yamaha inverter genset.)
The EMS will not allow unbonded neutral power into the coach as part of the protective schema. The plug simulates a bonded neutral on the generator.
Or, as I mentioned, I can bypass the EMS and allow the genset to power the coach, but that eliminates the protections of the EMS.
