pianotuna
Jul 28, 2019Nomad III
I don't see the reason to use an EMS downstream from the generator. You already know the voltage from the generator. The generator would stall out before voltage became too low.
There is also my pet peeve about EMS. The low voltage disconnect is far too low. I'm not comfortable with running the roof air below 107 volts.
