pianotuna
Jul 28, 2019Nomad III
Ed Gee,
Start with a hybrid (load support) inverter/charger.
Use the remote control to limit input amperage to what ever number works for you. Mine can be set as low as 5 amps.
If the voltage is low, it is possible to use load support to increase it by turning on the feature and then "trimming" the input amperage lower and lower. I do not recommend this--just that it is possible to do so.
Since I purchased an autoformer I have no need to "force" load support to do something it was not intended to do.
