dryfly
Jul 28, 2019Explorer
Planning wrote:dryfly wrote:
Planning......judging by your pictures you are successfully running an EMS with the modified male plug at the generator. Do you routinely do this or use the bypass feature of your EMS??
I invariably use the plug.
The only time I use the bypass feature is if I inadvertently forget to bring the plug, which has only happened once.
I do not use the generator often; the primary use is for needing power at the storage location for lights and battery charging while performing preventative maintenance duties.
It works well and seamlessly.
OK, then making and using the plug, or dongle shown above, sounds great and should do the trick.
I was under the impression that an accessory PI bypass kit was necessary if you want to go the bypass route, but just looked and it's a standard feature on the unit with remote readout model EMS-HW50C.
I think I got a plan now!
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
