Bobbo
Jul 28, 2019Explorer III
Planning wrote:
Mexico and other electric pros,
Slightly off-topic question.
When I purchased the RV, I specified to the dealer that I wanted the (separately purchased) Progressive EMS-HW50C hard-wire system installed as first in-line for all coach input, after the power cord but before the automatic transfer switch.
I just yesterday was examining photos I took of all components and noticed that they have it wired after the tfer switch, so that coach input goes through tfer switch, and then the output (either shore power or onboard Onan 5.5) becomes the EMS input. (I should have deduced that by seeing gen output readings on the EMS control panel for 3 years...??)
My question is, should I have it rewired to first in line, or leave it as is?
As you can see from the preceding posts, there is disagreement. I believe you need to leave it as is. Others feel just the opposite. My suggestion is to read the rationale that each side has put forward, and make your own informed decision.
Don't leave it as is because *I* said that is safest, but don't redo it because someone else says that is safest.
(We may both get some knowledge if someone answers my question above about what harm can be done if the EMS is after the transfer switch. One that will be stated is that it needs to be before the transfer switch to "protect" the transfer switch. Now, you have to decide if you would rather risk the transfer switch being damaged from bad shore power, or risk everything else in your RV being damaged from bad generator power.)
I really hope some will answer for the other side. I would like to be convinced by their arguments, but in 13 years of RVing, I have not been yet.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
