time2roll
Jul 28, 2019Nomad
Planning wrote:I would leave it as is. TS is not that sensitive to over/under voltage etc. Worst case you can bypass the switch or carry a spare. You want the main panel protected from all input and you have it as wired.
My question is, should I have it rewired to first in line, or leave it as is?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
