KD4UPL
Jan 03, 2021Explorer II
You're way too deep into electrical to not be using a meter. Those 3 light testers are handy for quick checks but will often confuse things as you have discovered. Get a proper volt meter and check for voltage you have: Hot - neutral, hot-ground, neutral-ground.
Did you ever plug in any of these 3 light testers before when running on generator? If not then you don't know if it's any different now or not.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
