Weldon's avatar
Weldon
Electrical or Air Cond. Problem?
Yesterday I decided to do some work on the 5er, having it parked at my residence. When I turned on the a/c the volt meter showed voltage around 105. Turned the a/c off and killed the power to the unit. Then checked the electrical connections for tightness...they were okay. I did discover the "dogbone", 50 amp to 30 amp I was using had one side which had been very hot and the cord felt hot. I replaced the "dogbone" the turned the power and a/c back on. The voltmeter showed 109, the a/c was runnning and sounded great. I stayed there and watched the voltmeter for about 10 minutes and all was well. I left the unit and when I returned, the a/c was barely running and the volt meter was below 100. I turned the a/c off and the voltage jumped back to 119 and what lights were on became much brighter. I am wondering if the problem could be the start capacitor and how does one check it.
Thanks for your thoughts!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
