MEXICOWANDERER
Jun 06, 2014Explorer
When the ignition key is turned on, the relay switch opens the normally closed negative cable connection for Row 2 and the fuses light up for use. THIS IS NOT HAPPENING....
Confusing description.
"opens the normally closed negative cable connection". Is not the relay switch the ignition switch?
This is yes/no a negative (ground) connection that is according to your statement "normally closed" but when the switch is activated the relay contacts open breaking the ground circuit? When the ground circuit is "broken" (made to go open circuit) by the relay the "lights, light up"?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
