deandec
Jun 10, 2014Explorer
Resolution of Problem:
The ground wire from the small terminals on the solenoid is not working. For some reason the ground connection decided not to work with no known event to cause that result.
A cheater ground connection has everything working as it should.
The next step is some continuity checking to find the actual ground point for the solenoid connection to see what else might be affected.
Thanks to all for your help.
Message to all: Check the Ground Connection First!! :o
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
