j-d
Sep 04, 2015Explorer II
wa8yxm wrote:
That 60 volts (RMS) comes from a voltage divider made up of two capacitors.. The capacitor is two metal pieces with insulation between them
The neutral wire and the safety ground in a piece of ROMEX = Capacitor
The HOT wire and the safety ground = The other capacitor.
Since all 3 wires are the same length that makes a 1/2 voltage divider.
Current limit is kind of tiny though.
So does this mean many or most rigs WILL tingle, even if wiring is OK on an Outlet Tester?
