Scout1457's avatar
Scout1457
Electrical problem at Tank Probes
I was working under my 5th wheel today and my sewage tank was exposed. There is one probe by itself with a white wire and on the other side there are three probes with different coloured wires. When my forearm touched the white wire on the tank probe I got a shock. I unplugged the trailer from 110V and no longer got a shock. When I plugged it back in I again received a shock. Any Idea what could be causing this? The tank is clean and my monitors are working
  • Because there is electricity flowing through that wire. I would imagine you were touching some part of the frame when you touched that wire and zap. Probably 12 volt coming from your converter. JMHO
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 15, 2026
