centracom's avatar
centracom
Electrical problem
Grand Design
Imagine 2970 TT
2017
My rig is at a full hookup 50a site. Several days ago the electrical appliances would shut off and immediately come back on. The air conditioner fan simultaneousy lose rpm. Today When I arrived at my TT the air conditioner will no longer turn on. The microwave is very slow to start and the lights in the TT seem to be dimmer than usual. All of the 12v outlet plugs seem to function.
My initial thought was the converter. But does the converter power the air conditioner?
Any suggestions would be much appreciated!
  • Sounds as if low shore power voltage may be an issue. Measure it under load.
    Is there a "whole house" inverter on the RV?
  • Check your shore power voltage. If it's hot and everyone's running air, that will kill your voltage.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I agree the issue may be on the 120 volt Shore power side of thigns as shore power feeds the conveter. which convets shore power to "Battery" power if the converter is not eating 120vac then it's not working (Technically that is a converter problem but... Well I think you see why it's not) This makes the lights dim and all but A/C fans run slower.
    Now the A/C fans and compressor are 120 volt devices but they may rely on 12 volt Relays to activate .
    Some differences between a trailer and motor home so I'll do it this way (motor home parts) note a trailer WITH a built in generator qualifies as "motor home" here
    One more (optional) part
    Suspect list
    Shore power
    Shore power outelt (park's problem so far)
    Shore cord plug
    Shore cord outlet (Optional if detachable) and the RV's inlet (LIkewise)
    (automatic transfer switch) (Built in generator only)
    Main breakers in main breaker panel
    Branch breakers
    Bus bars
    Check to insure breakers are fully seated (they have not tipped foreward and out
    And using a flashlight with shore cord UNPLUGED (If possible where you can see it) Check ALL screws and conections
    Many RVers I have found seem to have a few screws loose.. One of mine took a #2 square bit and 3 1/2 full turns of the driver before I was happy.
    While poking around look for any discolored wires (indicating overheat) sure sign of a bad connection.
    I will say again when working in the breaker box UNPLUG and if possible secure the plug where you can see it.
    There are also screws that can come lose in the Auto Transfer Switch
    Problems I have seen or personally had
    Bad park breaker
    Bad park outlet
    Bad plug connection (mine)
    Detachable cord outlet end screws not tight) A brand new 5er and I can tell you he was ..... well you can imagine what he was)
    loose screw on inlet (mine again)
    loose screws in the breaker box all over the place
    Bad connection on an internal plug/socket (mine added you likely do not have an installed hughes Autoformer)
    And on the 12 volt side of life.. in addition to dirty battery terminals and assorted other bad connections A BAD WIRE. yup. the wire was bad. (I had and I saw two others)
  • Not converter as most of your problems are 120 volts AC.
    I would be looking at shore power connector or twist lock connector on the rig.
    If you have more then one AC unit, try running the other.
    You need to verify voltage at pedestal with volt meter. Should be 120/240 for proper 50 amp connection.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
