tenbear
Sep 27, 2014Explorer
The GFI should have 2 wires, black is the hot wire and white is the neutral, going into it and 2 wires going to the next outlet in line. It also has a bare ground wire. If it does not have all 4 wires then the other outlets are not on that GFI and you will have to find a loose wire someplace else.
Thanks SMK for reminding me that all outlets may not be on that GFI.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
