tenbear
Sep 27, 2014Explorer
wickedinhere wrote:
The gfci has 2 pairs of wires coming out of it and one pair going in or it could be the other way around. The bathroom light was also out until i reset the gfci outlet i thought that was strange since the light is 12 volts.
If the 2 pairs are on the load side of the GFI, then the problem could be in either of the 2 branches. If the 2 pairs are on the input side you only have to worry about the single pair on the load side. The GFI should be clearly labeled as to load and source?
I can think of no reason that the bathroom light should be affected by the GFI.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
