tenbear
Sep 28, 2014Explorer
wickedinhere wrote:
OK i went and pulled the gfci outlet to check to see if the 2 pairs of wires were going out and they were. I checked the 3 outlets in the bedroom and they worked then i checked the other ones and they were working so they are all working now. The only thing i did was pull the gfci back out the wall so i figured i have a loose wire so i moved the wires around trying to get to give me problems but it didn't. I have no idea what was wrong but its working now if i had to guess what the problem was i would say its with the gfci and its wiring. Thanks for all the help i also now know that i only have one gfci i think. LOL
Glad to hear your outlets are working.
While you have the GFI out, tighten all the screws and if you are using the push in terminals that some GFIs have, it may be better to switch the wires over to the screw terminals.
You might want to check the connections on the first in line outlets too.
Hope they all stay working.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
