redink wrote:
I'm trying to find the best place to connect 4 gauge wire to run directly back to my Lance camper's charging relay for more charging from the alternator.
I have a connector and plan 4 gauge all the way to the battery after the blue seas 7610 and of course a fuse right of where I tap fpr the power from the truck.
Waste of time and money !
Your truck uses a "smart charging" system. A few minutes are starting the voltage get reduced to about 13.2V. Even with a 4 gauge wire to the camper and assuming ZERO voltage drop, 13.2V is not enough to RECHARGE a lead acid battery. Yes, it will prevent it from discharging, but it will NEVER FULLY RECHARGE !
Buy a DC-DC battery charger and use the stock wiring.
