wopachop's avatar
wopachop
Electrical smell from water heater
Getting a weird smell of hot electrical. This first happened months ago so i stopped using the 120v element. On propane it works great.
Finally tested the heating element and it had the same resistance a couple help videos said i should see.
Pulled the element and it had white deposits but not too bad. My anode rod can completely fallen off. I had wondered if maybe the rod was interacting with the heating element somehow.
I fished the broken anode rod out. Cleaned everything real good. Used a shop vac and piece of hose to suck the remaining white deposits out.
Filled the water heater and turned it on. The smell is back and it seems slow to heat. After about 45 mins i turned it back off. Water was just a little bit warmer than how it comes out cold.
I have the Suburban paper manual here. Not seeing anything for electrical smell.
I bought the tool to remove the heating element. But waiting to buy a new element because the one i have is testing ok. Would be happy if thats the simple fix.
Any thoughts on what part is making the smell. I have a fire extinguisher by the front door ready to go. Turned off the breaker to the heater and the switch is off. (side note the switch broke, so i jumpered it, thats when this smell first happened months ago)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
