enblethen
Mar 02, 2018Nomad
Fuse by battery? Main fuse in 12 volt DC power distribution panel normally located under small metal plate adjacent to the 120 volt circuit breakers.
If you are connected to shore power, your converter could be bad. It could have reverse polarity fuses on the DC end of it depending on model.
What happens when you plug into your TV?
