tandkj's avatar
tandkj
Electrical Switches
Immediately inside the MH on the left are lighted switches. One switch is for the battery shutoff that is broken. The switches are lighted and have a built in ID (battery shutoff). Does anyone know where I can get replacement switches with the built in ID??
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    If you can get some numbers off the switch, often you can google it and find the mfg and a supplier.
  • tenbear wrote:
    I would go to the RV builder. The battery disconnect switch in mine is a very specialized switch, Press the top, one polarity is sent to the solenoid, press the bottom, the polarity is reversed.
    Very much so!
    The only part of the switch that is broken is the rocker part. I still have power and everything is OK, just the rocker part. I have it lsaying on the dsah, will call Monaco today.
    Thanks!!
  • If it is the inch wide by about 1.5 inch switch get a flashlight and magnifying glass to get the part number off the side. In a pinch you may be able to swap it with one of the others on the panel.
  • I would go to the RV builder. The battery disconnect switch in mine is a very specialized switch, Press the top, one polarity is sent to the solenoid, press the bottom, the polarity is reversed.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Is this a Intelltech Battery Control Center setup... I ask cause it matters to the switch.
    But contact your body builder if all else fails.
  • Probably a carling switch and available at a local rv store. IF the outside part you push on is not physically broken it can be snapped off and installed on a new switch.
    Are you positive it is broken? The switch controls a relay in the front run bay which is the large control panel below the driver in the outside compartment. The relay is a common failure component. It can be bypassed easily to get you going.
  • RoyB's avatar
    RoyB
    Explorer III
    Quick search on GOOGLE came up with this version. Remains me of my missle silo days in Arkansas...
    STACOSYTEMSLIGHTED SWITCH
    You probably need to post a picture of what yours looks like
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
