mena661
Mar 30, 2014Explorer
One or both batteries are bad. Unless you have a bad fuse somewhere, you pretty much eliminated the charging systems. I would put one battery at a time on the chargers (use the inverter/charger it's quicker). Fully charge it, disconnect for 24 hrs then note the voltage. Repeat for the other battery. Post the results
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
